paul b b
is this ok? or bad practice?
thanks
paul
thanks
paul
If you mean, for instance, 2 radial socket circuits on one MCB; yes its fine, as long as the breaker is selected for the protection of either cable, and all other necessary values are met.is this ok? or bad practice?thanks
paul
I am not getting in to arguments tonight have bills to do.But Batty doesn't like it!
not good practice, but nothing dangerous about itWhen I changed a CU recently I found that the old CU had two rings into one 30A 3036.
Your lucky I usually find they are four radials.When I changed a CU recently I found that the old CU had two rings into one 30A 3036.
