- Mar 28, 2008
- 14,521
- 1,199
Got a customer with a big old house and various 2-port motorised valves.
Each wired from their own little FCU connected via a thermostat in room to turn rads in that room on/off.
One valve appears to be not working... I have checked all electrics.. all seems good but the valve would appear to be doing nothing.
Needs new valve.. which is no problem for me do, BUT the existing valve is an old one AND it is connected onto 15mm (or probably imperial sizes its an old valve!) pipes.
Not your typical 22mm 2-port motorised jobbie!
I had a quick look.. but thought perhaps you could point in the best direction to get a 2-port motorised valve with 15mm pipe connections.
any links?
Thanx
any links?
Thanx
