2 way circuit diagram
PoorFish
Oct 22, 2008
158
Would anyone be kind enough to tell me which one of these circuit diagrams is correct. it is supoosed to be of a 2 way 2 light lighting circuit
thanks in advance P
faster than your reply i suppose....i take it the one on the right is good????
but does the op know why it will go bang ???
or was he just testing Andy ???
I have thought about it and .......
is it to do with .....
I've had a hard day lads...
basically the first is all in parrellel
the 2nd one has the switch in series
im i giong in the right direction here???
I have thought about it and .......is it to do with .....
If this was a 1 way switch it would only go bang on 1 setting!
What is the switch doing?
where does the electric go? (remember it takes the path of least resistance....)
The first 1 the switch is connected directly to the neutral.
The second 1 is correct because the phase is switched then goes through the load and into the neutral.
If my understanding of this is wrong then I might aswell pack it in now Pray
That's right - It is connected to the Neutral. :)
The first 1 the switch is connected directly to the neutral.The second 1 is correct because the phase is switched then goes through the load and into the neutral.
Absolutely.
So there's more resistance for the load through the lamps so the current goes through the switch and gives a L-N short and bang!
:D
Of course
I do understand what you are saying
but what if the switch was turned off...
thanks again all.
Of courseI do understand what you are saying
thanks again all.
if the switch was off nothing would happen!
the circuit is 'open'
it's easier to think of with a one way switch but the principal is the same
thanks again all.
The circuit would function correctley, only it would be permanentley live.
so if the circuit was connected up like this and the switch off,
the lights would be turned on....
so if the circuit was connected up like this and the switch off, the lights would be turned on....
For circuit 1: With the switch turned off(open) the lamps would be on and no bang should happen if it was wired up correctley. If you turned the switch on(closed) it would go bang.
Hope this clears it up for you.
