Blue Fox
- Dec 12, 2008
- 351
- 1
Hi Guys & Gals!
Called round a house today to change a smashed 2 gang light switch. Opened up the switch and found it had been wired using 2 3 core and earth cables and a twin and earth with all cores used. The yellows cores went into the commons on both the gangs, one of the reds from the 3 core and earth went into the L1 with the blue going into the L2, on the other gang the blue from the othe 3 core went into the L2 along with the black from the twin and earth and in the L1 was the reds from the 3 core and the twin and earth? Replaced the face to test circuit but found upstairs switch didn't switch on/off downstairs hall switch but had to be turned on or the downstairs switch wouldn't work on the downstairs light. THe upstairs light works fine from upstairs but if it is turned on downstairs when its turned off from up stairs it blinks as you flick the switch but stays on? Believing I'd made an almighty error got a bit concerend until the home owner said thats how its always been since we moved in! The asked if I could put it right so going back again next week but wondered if anyone had any idea what was going on to save me a bit of time and hassle. Think the previous owner was a bit of a "diy'er" as the switch I think was originally the downstairs switch for the upstairs light is now blanked off. Do people think I would be better just starting again and rewiring it or struggling on? The cables run inside the walls in conduits so are airly accesible.
