203 Questions
Mikeymike
Feb 7, 2010
36
Yo all anyone whos got the 203 coming up heres a past paper. hope this helps alittle :)
24 Questions & Answers are on the next post.
1: When work has been completed at the end of the installation you should
a: Leave the area unlocked for more efficient start of work
b: Clean and tidy and leave the installation in a safe condition
c: Put your tools away and leave the labourer to tidy the installation
d: Drive away in the works van
2: Excess current that flows in a circuit which is electrically sound or healthy is known as
a: Short circuit
b: Earth fault
c: High resistance fault
d: Overload
3: Electricity is generated at what voltage before transmission
a: 400KV
b: 275KV
c: 25KV
d: 132KV
4: The safe angle when erecting ladders is
a: 25degrees
b: 45degrees
c: 75degrees
d: 80degrees
5: The maximum recommended lifting weight for a healthy adult male is
a: 18Kg
b: 25Kg
c: 15Kg
d: 20Kg
6: After completion of work on a contruction site, we should
a: Leave site clean and tidy & store materials & tools in a safe secure place
b: Put the tools in the back of the van
c: Return the materials to the stores and leave the waste in a pile out of the way
d: Ensure that the site is locked
7: Standard transmission voltages that are used on the Supergrid and National Grid can be respectively
a: 132Kv & 11Kv
b: 275Kv & 400v
c: 400v & 230v
d: 400Kv & 275Kv
8: The fire Extinguishers that are most acceptable to be safe used on electrical fire are
a: Water and carbon dioxide
b: Carbon dioxide and powder
c: Powder and water
d: Foam and water
9: Power factor can be expressed by
a: The dividing of apparent power by true power
b: The dividing of apparent power by reactive power
c: The ratio of apparent power to true power
d: The ratio of true power to apparent power
10: Emploters have to provide under Health & Safety law
a: Breathing apparatus to all employees
b: Relevant safety courses
c: Food and drink facilities
d: Direction to the construction site
11: If the Line voltage in a 3 phase star connected system is 660v, what is the phase voltage
a: 380v
b: 696v
c: 230v
d: 1143v
12: The power rating of a lighting circuit containing fluorescent luminaires can be calculated using the rated power multiplied by
a: 0.725
b: 1.5
c: 1.8
d: 2.0
13: The first procedure to be carried out when arriving on site is
a: Inform your supervisor you have arrived
b: To put the kettle on
c: Isolate the supply
d: To carry out a risk assessment
14: A glow type starter completes an electrical circuit in a fluorescent luminaire using
a: A relay
b: A magnetic field
c: A bi-metallic strip
d: A contactor
15: The first 2 stages of the risk assessment process are
a: Identify the hazard and record the findings
b: Evaluate the risks and prepare an action
c: Evaluate the risks and record the findings
d: identify the hazards and evaluate the risks
16: How do we most commonly obtain safe working voltages when working on a construction site
a: Using an RCD
b: Using a generator
c: Using a transformer
d: Using an MCB
17: A capacitor used for power factor correction in a fluorescent luminaire is connected
a: Across the supply terminals
b: In parallel with the glow type starter
c: Across the choke terminals
d: In series with the glow type starter
18: The quickest and most flexible form of communicating drawings is by
a: Post
b: E-mail
c: Microfiche
d: Fax machine
19: The capacitor connected across the glow type starter in a fluorescent switch start circuit provides
a: Bi-metallic strip switching
b: Power factor correction
c: Radio interference suppression
d: Current limiting
20: One method of ensuring that the drawings are easy to interpret is by using
a: BS EN60898 symbols
b: BS EN61009
c: BS 1362symbols
d: BS EN 60617
21: A resistor and an inductor in a series circuit have a resistance of 6ohms and an inductive reactance of 8ohms respectively. What is the total impedance
a: 14ohms
b: 10ohms
c: 100ohms
d: 12ohms
22: Transformers operate with a lagging power factor and hence are rated in
a: KW
b: KVA
c: KVAr
d: Amperes
23: Waste material that could be considered to be hazardous should be
a: Taken to the nearest council refuse plant
b: Stored in the site container
c: Removed by a licensed contractor
d: Left on site for someone else to deal with
24: Typical distribution voltages for the transmission of electrical power are
a: 400v & 275v
b: 132Kv & 11Kv
c: 275Kv & 400Kv
d: 11Kv & 400v
1 b
2 d
3 c
4 c
5 b
6 a
7 d
8 b
9 d
10 b
11 a
12 c
13 d
14 c
15 d
16 c
17 c
18 b
19 c
20 d
21 b
22 b
23 c
24 d
