240v Ice cream machine into a 230v Generator
taxidriver0069
Aug 1, 2011
6
Hi all, new here.
Just trying to sort out a problem for the mrs. So all or any help would be greatly appreciated :)
The mrs. has been trying to convert a minibus into an ice cream van. We are now at the stage where we need to power the ice cream machine. We are trying to use a generator for this.
Here we go: On wash/rinse cycle the generator runs fine switch the machine to run the mix through and the breaker on the generator is tripped straight away. And we cant seem to get past this point. I will now supply the specs of both machine & generator so please any help would be great, thanx.
The Machine: Taylor Freezemaster 320-44
240v
Min amp 17
Max amp 20
Phase 1
Other motor amp 7
Cy 50
Compressor 7.5 RLA
Beater 6.1 FLA
60.0 LRA
This is all the info i can find on the machine.
The Genny. Loncin 6500DDC 6.5 KVA Petrol
Rated voltage 115/230v
Rated frequency 50Hz
Rated output 5.0Kw
Maximum output 5.5Kw
Power factor 1.0
Many thanx in advance :) Taxidriver
concur with Apache,
its not simply the running current that is so much an issue, I dont think,
but more the inrush/start-up current,
generators should really be sized at the largest load then doubled to allow for the inrush/start-up required,
seems like your generator simply isnt big enough,
this may, or may not be the total issue, but from the limited info on the internet, and not being able to actually measure the required current required this deffo sounds like the most likely problem.
Thanx very much for rapid reply,
Sorry im not very clued up on the mathmatics & understanding of electrics.
So what is needed from the genny or is their a way around this issue. to stop the breaker cutting off?
Cheers :)
The van is parked in a yard with the use of a power hook up. The machine did run fine but for only about 10 - 15 mins. no breaker in the hook up point so blew the fuse which was a 16a.
your ice cream machine may run on the generator fine on paper,
but it needs a much larger current(more amps) to start, than it does to run,
and in all honesty, even when running it would be pushing your genny hard all the time, which isnt a good thing, gennys are mostly designed to have something like a 60% load,
this is why soft ice cream vans are running, they use a slightly different technology, involving larger alternators and invertors, alongside purpose built ice cream machines,
I assume your machine is a normal shop one, hence the largish loading from it.
---------- Post Auto-Merged at 23:01 ---------- Previous post was made at 22:59 ----------
that sounds about right, typical overload for which the breaker is designed to cope with for a limited time.
Thanx everyone for all your help. I will leave this thread running. Just in case any other options are available to us.
So really we are looking at a Larger Genny or a different machine with a lower ampage yeah?
Cheers much :)
bigger genny is into a lot of cash TBH, and diesel,
you really need to look at a mobile ice cream machine, not a normal shop one,
only my opinion mind.
Guys would this run on our genny?
MODEL: CARPAGIANI 191 BAR
240V 13AMP PLUG
GRAVITY FED
2.1KW
MACHINE CODE: 822217001
Thanx again you've all been legends :)
on paper, yes deffo, 2kW should do so easily enough,
even on a start up should only be max 4.5kW so should be OK,
please dont quote me and come after me if it doesnt, I'll blame the guy next door anyway.! :D
but that does sound more like it,
BTW, your genny will get a hammering if you intend running this all day.!
