stholt5233
- Joined
- Jun 19, 2019
- Messages
- 3
- Reaction score
- 0
Trying to hook this machine up, it is 3 phase, but there are no neutral or ground wires to connect, only the 3 hot wires?? It is an older machine, it was apparently purchased about a year ago,but never hooked up. I have 3 phase in the shop, but I am a little unfamiliar with wiring 3 phase.
I have done a fair bit of residential wiring over the years(in the States) but no 3 phase. To my understanding, I should have at least 4 wires, 3 hot(phases) and one neutral. I only have the 3 hot wires coming out of the machine in a little junction box on the side. The wires are marked 1-2-3. These wires follow up to a 3 phase rotary switchfuse, from there to the control switch and motor.
I see no ground strap or lug, or neutral wire or anything like that, other than a case grounding wire on the motor itself,so i am a bit puzzled. You still need a neutral(ground) for this to work, right? Am I missing something?
Cheers, thanks.
Cheers, thanks.
