would be nice to see some answers for the above.These are possible questions as well (Cheers Matty)Applaud Smiley> state one application for each of the following voltages in relation to the distrobution of energy:-
230v
11Kv
400/230v
> with ref to BS7671 define 'electrical systems'
> state the safe isolation procedure
> name faults that may cause a switch start fluro luminaire not to work
> state safe working practices necessary in terms of isolation
> what is 'on load' and 'off load' and give examples...
> draw various electrical symbols (back page of the OSG sleeve)
> state basic principles involved when undertaking fault diagnosis
> list test instruments and what they are used for
> identify documents to be completed following a periodic inspection and test
Have a go yourself and we'll mark youwould be nice to see some answers for the above.could someone tell me theranges for the test meters used please?
thanks.
are you really a vet.Have a go yourself and we'll mark you![]()
Better than just being told the answers!
yes I amare you really a vet.
I can never remember these either... Doesn't the continuity meter go from 0ohms - 200ohms and the Insulation Tester go from 200Mohms to 0Mohms? It depends really because different meters have different test ranges.could someone tell me theranges for the test meters used please?
I had exam last week and had same sort of questions !i think they are mainly for 302 paper i have heard 303 is similar though.I found this info in another thread from someone who has taken exams if anyone has ideas on the answers or any other sample questions any contributions are welcome B-):
List operating voltages for selv, sodium lighting, 3 phase motor?
State three considerations to be taken into account when rectifying a fault in a busy work area?
State three factors which may affect carrying our repair work on an installation which is in use (very similar questions I know)?
Name the three forms which would be completed upon completion of a periodic inspection , state who determines the length of time between inspections, who completes the paperwork, and to whom the paperwork should be given?
There was a schedule of test results with 3 departures from 7671 which must be identified?
for a Ze test:
state why the circuit must be isolated?
state the reason for disconnecting the main earth?
i can't remember the third...
There was a simple lighting circuit diagram with three faults on it which you must identify
There was a more complex circuit diagram of a 2 way with intermediate lighting circuit and three roses, again there were 3 faults to identify
i just had 302 exam thought it was quite easy got 301 in 3 weeks any advice ?Hi all,I know transmission,how to make an area safe,safe isolation and test procedures might come up but has anyone already sat the exams? Does anyone have any sample questions for L3 302/303 written exams or any idea what to revise?i have both exams next week and I want to make sure that I have them covered. Any advice would be much appreciated.
Cheers
230v
11Kv
400/230v
You have to have a certain amount of posts before some areas and functions will work. Its to stop spammersHi ive tried to send you a message but wont let me for some reason.. have you or anyone got the actual questions for these tips???
thanks you x
