Lukeyw
Hi I have been asked to look at the lighting at my local sports centre. I been to look and the set up is as follows.
3ph supply TN-C-S to a 4 pole 63A RCD, This feeds two isolators that each feed 3 stantions either side of e pitch. The lights are 3x 2KW high pressure sodium lamps per stantion. So 18 all together.
The problem is this, the RCD trips if all lights are turned on, but only when they get to full load after about 15-20 mins. If one side is left off all is good. Now I have checked the RCD and all is fine with that, there is no neutrals on any of the installation after the cut out. My theory is maybe some functional earth leakage due to no neutral and the RCD is picking this up as a fault?? I'm a bit lost
Any help would be great
Cheers Luke
Cheers Luke
