so basically youre god of electrics and can do anything else because its easier than what you do now? well if it was that easy you wouldnt need to ask what flex to use to make an extension lead
Jamal,
You can and could have got a lot more information if you had come to the party with a different attitude.
You are not the only Engineer who has been on the forum.
The level of answers you get are based on the way you post the question.
The readers have no idea what you are trying to do, nor your competence.
If you want help you must explain yourself correctly.
You are right. I didn't come to the forum to learn everything there is to know in few hours. I came here so that someone can point me in the right direction so I can then go and do my own research and see what I can come up with and come back here and talk about it. This is how you learn. Its a feedback process. I don't even know why I thought that an electrician forum would be the place to get some help.with some proper design & planning, there are other potentially easier options available... and i doubt im the only one who has already thought of them... however that is not something you can learn in an hour asking a few basic questions on a forum...
Not the one I am getting. They come in both three phase and single phase units. I am getting single phase one.Em......can I just ask a question?
Isn't the Clarke compressor you mentioned a three phase unit?
Hi Jamal,
"How will I install the cable? Is that supposed to be a tricky question?"
It is a serious question.. See, when you select a cable, the problem is, there is no such thing as a "40A" or any other capacity cable. That is its tabulated capacity, but you must apply all sorts of correction factors for things like how the cable is installed, [duct tray clipped direct etc] insulation round or on it, is it run with other cables, ambient temperature and stuff like that to come up with the ACTUAL current capacity. You need to be checking volt drop and R1 + R2 for the circuit to work out what Zs will be and will it be low enough for your selected OCPD..
Anyway, you need to split the tails with Henley blocks and then use these to feed your isolator/OCPD for the cable. A switch fuse would be best. What TYPE of cable were you thinking of using to feed the new socket?? For your extension you definitely need HO7RN-F like this stuff http://www.nexans.co.uk/eservice/UK-en_GB/navigate_300462/LINEAX_H07RN_F.html
What earthing system does your house have????
Please do not think people are being awkward.. There is MUCH more to this than you realise.. What testing equipment do you have???
john..
Yup they do a lot of variants and there are only two of them that are single phase supply.Ah, just wondered. I installed one in a workshop but it was the three phase job.
Nor me,Not where I am !
Hi
I have an existing socket in garage but I presume that these are normally rated at 13A? Also the wiring mostly likely won't be able to handle 40A? What is the easiest/cheapest way to get a 40A socket in garage?
I can think of a few ways of re-writing the whole thing but that will be a long job and will cost a bit. Any suggstions are welcome.
Thanks for the help.
so telecoms should be a piece of cake? & alarms, child's play?Are we seriously comparing a simple house wiring to the complexity of 132-400kV systems?
