Will 4mm flex be ok within consumer unit and then under floor boards to feed an induction hob? (properly clipped direct obviously)
Red book gave a 4mm cable due to the amp draw on the hob so I proceeded to my supplier and asked for 10m of 4mm cable at the electrical counter. He went away cut the cable and came back with 10m of 4mm flex when I queried this he said he had cut it now and that it should be fine. I am just wanting to get confirmation on this as the CU will be getting inspected.
