5/20 glassfuse 20A
moose man
Aug 8, 2009
510
hi all can anybody suggest were to get this type of fuse can find 30mm @20A but not 20mm its off a codenser unit for a compressor
my local wholesaler don stock them
thanks moose man
RS stock them try order code 975-620 or 975-783. So if RS stock them so will Farnell as I think the companies are related.
Hope that helps.
thanks roys had a look part num relates to a 30mm fuse its 5/20 slow blow
scond part num cant find
moose man
I find that this universal fuse will suffice in the majority of cases......and is is 1000MA short circuit as well
:coat
RS stock them try order code 975-620 or 975-783. So if RS stock them so will Farnell as I think the companies are related.Hope that helps.
roys,
Farnell & CPC are the same co mate, RS are competitor
---------- Post Auto-Merged at 11:20 ---------- Previous post was made at 11:18 ----------
Moosey,
Try this if you are desperate, never bought off them but they claim that if they don't sell it, it is not made!
5X20MM SLOW BLOW GLASS (T) 20AMP 250VOLT FUSE
roys,Farnell & CPC are the same co mate, RS are competitor
Moosey,
I was about to stick a link up for 'The Fuse Company'...
But slidy snake's already there!!
p.s.
I have bought off them a few times..
always had good service..
no problems.
Thanks sidewinder & special location i give them a ring on monday got to get sorted quick getting lots of water in air lines give me hell with the machine @ work special the air clutchs on the press's
moose man
