I have chased a wall to 50mm, unfortunately before reading the posts here and on other sites giving the maximum chase depths X(
Is it possible to use tubular reinforcing steel bars like those in the link below to run cables inside in addition to reinforcing the wall? Don't want to have to brick the chase up if I can help it :|
Gavin.
50mm x 50mm x 5mm Mild Steel Box, Mild Steel Box Section, Mild Steel | Metal & Plastic online Metals4u
Gavin.
