6mm socket radial
tom1
Distinguished Member
Aug 7, 2009
2,330
added another socket to what used to be a cooker radial, 6mm on 30a mcb,
had to swap the socket for a cooker switch with socket to could not fit two 6mm in normal socket. ran 6mm from the cooker switch side to the new socket
i have used in the past sockets with 2 line and 2 neutral terminals but cant find any one who sells them.
is it ok to leave it on a cooker switch?
any other solutions?
thanks
nice one mate, do u know how much,
went to one supplier and the best they could do is a cooker switch
You could always put cables in wagos first and then one to socket and other cable to the other socket if you get my drift. The red 41 amp ones will take 6mm cable.
Batty
will change that tomorrow then mate thanks
The one I was on about has brown and blue terminals... (2 screws in each) and 6.0mm fit's quite easilyglad you got it sorted.
thats what i wanted in the first place cef was on the other side of town, but its in now
thanks for help
