- Dec 25, 2011
- 5,470
- 80
I'm contemplating making use of a roll of 7-core 2.5mm sq armoured I have as in it seems a pity to NOT make use of it. It came off site where it was used as a temporary feed to some plant and I asked and was given it. Hypothetically could I pair the cores up to give 3 x 5mm sq? I was thinking sleeve them brown / black / grey then fit bootlace ferrules over the twinned 2.5's. I know some of the larger armoureds are done like this to make for easier handing. Before I even consider it (length of run, installation method, load) I'd need now it's current carrying capacity in this configuration - obviously more than 4 and less than 6mm sq but pretty sure that just doubling the rating for 2.5mm sq is maybe not the way to go! Any thoughts? Many thanks.
