Ross Stoddart
[SIZE=medium]Ok Be Gentle,[/SIZE]
[SIZE=medium]I have the Accenta G3 Home Alarm with the following Panel:[/SIZE]
[SIZE=medium]http://www.davyscott.com/images/accenta_remote_keypad.jpg[/SIZE]
[SIZE=medium]The Alarm has 8 zones (as follows)[/SIZE]
[SIZE=medium]Zone 1 Front Door[/SIZE]
[SIZE=medium]Zone 2 Hallway[/SIZE]
[SIZE=medium]Zone 3 Living Room[/SIZE]
[SIZE=medium]Zone 4 Dining Room[/SIZE]
[SIZE=medium]Zone 5 Kitchen & Utility[/SIZE]
[SIZE=medium]Zone 6 Landing[/SIZE]
[SIZE=medium]Zone 7 Garage[/SIZE]
[SIZE=medium]Zone 8 Office (External to the main house).[/SIZE]
[SIZE=medium]The issue is as follows:[/SIZE]
[SIZE=medium]When you walk in and deactivate the alarm, both the green (day light) and red (power light) are lit, all zones are deactivated (however every 5 mins the internal panel alarm provides a single beep). I contacted the previous house owner and he suggested the following:[/SIZE]
[SIZE=medium]Type in Code and Press Program then 3. The single beep will stop, Zones 1-7 will be activated but Zone 8 will remain activated. [/SIZE]
[SIZE=medium]Now whilst this solves the annoying internal 5 min beep it unfortunately means every time I walk into the office the external alarm sounds.[/SIZE]
[SIZE=medium]At the moment I have one of 2 situations:[/SIZE]
[SIZE=medium]Ideally want to incorporate zone 8 into program 1 so it behaves like all the other zones.[/SIZE]
[SIZE=medium]The key pad does not have a LCD so simple step by step what to press would be appreciated.[/SIZE]
[SIZE=medium]Thanks[/SIZE]
- [SIZE=medium]Program 1 where all zones are deactivated but the annoying 5 minute internal beep from the panel happens. Or[/SIZE]
- [SIZE=medium]Program 3 where zones 1-7 are deactivated, the annoying panel beep stops but Zone 8 remains armed.[/SIZE]
