Hamzaan
HI,
I'm trying to modify an electric Moka pot imported from Germany, so it is fitted with a schuko plug and has a complimentary uk adaptor, to boil slower and therefore produce better espresso. (FYI: with standard, i.e. stove top, Moka pots the recommendation is to lower the heat and have the coffee boil through slowly or quick boiling new coffee smothers the crema)
I thought by adding in a resistor I could lower the power of the heating element, which should slow the boil hopefully. I'm not sure how schuko plugs are wired, but if they have the same wires as we would find in a standard UK plug I was thinking I could strip it back to wire it into a normal uk plug and solder in a resistor just before the neutral terminal. Could that work?
Any ideas welcome, cheers
Hamzaan
Hamzaan
