Berserkerboy
I know what you mean about the quoting company. Some sales teams are keen to the point of being rude, whereas others are more relaxed knowing that they win some and they lose some.
Who the firk is Andy? A Youtube 'expert' by any chanceI’ve been watching more of Andy’s off grid garage journey, and it occurred to me at the weekend, from a simplicity and cost point it view it would be better to use four MPPT 150/35 charge controllers, with three panels on each string. Whilst this won’t work as well as SolarEdge optimisers with regards to shading, it probably wouldn’t be far behind, problematic panels could have Tigo optimisers fitted if need be.
This approach would reduce maximum usable power, as the new array and batteries would be just through the Multiplus II, which unless I went up a size (a lot more expensive) would be limited to 4kw output, but it’s not often we’d exceed that anyway.
The existing array could be run in to the critical loads output, and thus both arrays would keep running in an extremely rare power cut, supplying power and charging the batteries. The fridge freezers (on their own circuit already), lighting and perhaps some emergency sockets could be run off the critical loads circuit. This would of course require two new cables from the garage.
Would the Multiplus II be able to handle the existing 4kw array on the critical loads circuit and would we be able to use say 7kw of solar if both arrays was producing 3.5kw?
What's you're thoughts on the above?
@Ronski@Berserkerboy I think you misunderstand. I fully intend on doing the G99. The question is whether I let a solar company that's only doing a quote apply, or whether I send the form in listing my ideal hardware.
I've no idea what the solar company is going to apply for, and I've no idea if it will cause complications if I go with a different company - remember the company that wants to apply hasn't even given me a price yet, it feels more like they are trying to lock me in, and make me feel I have to go with them.
It's not so much the array your DNO is interested in, it's the inverter and what's being backfed the grid, if anything.@Ronski
I finally find someone with a very similar project. You seems to be head of me though.
I got a 4kWp installed in 2016 facing south. All good. I have additional space (not as much as you though) for 9 panels 3 facing south, 4 facing west and 2 facing south west. Originally the company said I could have 3.5kW. However, after looking at what the same PV provider (JA Solar) offers, I have found that I could combine (with a Tigo optimiser) different panels and reach 4.75kW. In addition to this, I am planning to have 10kWh batteries (for now) to be charged by the new panels and the existing 16 panels. This part has been sorted even if this means some losses in order to keep my FiT
I am struggling to understand what I need with regard to DNO. I did ask the company to inquiry and they have done it however I think they went asking for the 3.5kW while I am keen to have 4.75kW (or even more if I find panels more powerful that still fits).
How far are you with your project?
Cheers
Bob
As Binky has said, what the DNO is looking for is the maximum power you could export. So the total of the installed inverters, and battery if that has its own inverter. I have an application in with my DNO, but am awaiting a reply.I am struggling to understand what I need with regard to DNO
No need to lose the FiT, which is nothing to do with the DNO. Put in a G99 application for the second system a describe it as set for zero export or capable of being set to comply with whatever they will allow you to back feed to the grid..
On the other hand, I am not interested in exported if this creates more hassle. I am willing to lose my export tariff (from my existing system).
