Advice on setting up solar, to power a router and wi-fi
spagettilegs
Oct 31, 2023
Ireland
Running a router and a point to point Wi-Fi system off a solar panel.
A friend wants to send point to point Wi-Fi from a road to his house which is 500m away and there’s no power at the road.
The system he’s looking at is a (POE 24V/0.5A) https://kuwfi.com/products/kuwfi-2-...oor-cpe-kit-point-to-point-wireless-bridge-92
As far as I can tell a standard router uses between 5W and 20W
My question is, what size solar panel would be needed to keep a battery charged enough to run that kind of setup 24/7?
Obviously there would be less use late at night.
Thanks for any pointers.
(Title edited to be specific)
What is he looking to do with this ?
Is it just a WiFi extension from the house to extend the range ?
If its just that you can get external WiFi antennas with over 1km line of sight range.
A lot will depend on your Worst Case Scenario.
For instance, you get a week with no sun, like recently :-<
The bridge requires 0.5A at 24V.
You will require a 24 x 0.5 x 24 x 7 = 2kWh battery to keep a 24/7 connection for a week - about £300 ?
And enough PV panels to keep that topped up.
Let's say 24 x 0.5 x 24 = 300 generated watts per day, to keep topped up for the cloudy days.
Say double that to cover low generation mid-winter.
Two 400W PV panels, about £200 ?
24V 800W Inverter, about £200 ?
Much easier (and cheaper) to go with mort's high gain antenna at the house.
