An electrician has fit a new fuse panel (Twin rcd etc) and it's tripping with one of my TV's plugged into the ring main, but only if the aerial is plugged into the TV (I have a tv loft box and sky+ with tv eye links).
He's blaiming my gadgets (computers, X10, pc's etc, but I unplugged them all), but his 'tester' friend said it's an earth fault and found a high reading on the earth test, getting higher further away from the fuse box.
The tester guy has suggested to earth one of the high rated sockets back to the radiators as a test, and also to take all the sockets off and look for a broken or loose earth. My electrician seems to want more for this service, even though he told me before and during the job that his price was expensive compared to buying a panel in B&Q as we are paying for his time and that sometimes these jobs take days to find a fault in a socket... sounds like he said the scenario we hit, but now wants extra.
Couple of questions,
1) Does it sound like an earth fault?
2) Should this be included in the job of fitting the new panel?
3) Is having a 'tester' sign off the work normal, or does this mean he's not fully qualified?
4) Is he allowed to pull the leccy boards main fuse out of the leccy boards inlet?
thanks for any advice offered guys...
