or better still, bypass the loftbox completely by using F-F connectors on your TV and antenna connectors, (I assume they are F type),Right.Unplug ALL the other aerial leads into and out of the loft box, so you have JUST the tv plugged into the mains, the loft box plugged into the mains, and just ONE coax cable plugged into the loft box, that being the one that feeds the aerial down from the loft box to the offending tv. The ONLY thing plugged into the tv must be the aerial lead from the loft box, no scart leads, hdmi leads or anything else, no DVD players etc.
Does the RCD trip?
If yes, then in all probability the tv AND the loft box are faulty.
If no, the RCD does not trip, then start plugging the other cables back into the loft box, ONE AT A TIME, i.e the aerial feed into the loft box (from the sky box in the other room) then any other outputs to other tv's.
Then tell us which cable being re connected causes the trip.
If still no trip, re connect, again one at a time, all DVD players, freeview boxes etc.
If you can, sketch out a detailed drawing of ALL the tv's, sky boxes, freeview boxes, amplifiers, splitters etc so we can fully understand the installation.
AS my previous post, you need to do that test. 6 other tv's means 6 other potentially faulty items that could introduce the voltage to the aerial socket that upsets this tv, and with that many tv's we really could do with a sketch of how it ALL is wired up.HiYes I have and the rcd doesn't trip. 6 other TV's in the house all plugged into loft box also work ok. So maybe the lg is faulty, i could take it to a friends house and see if it pops their rcd (quite big to get in a car tho) but if they don't have a loftbox is it a true test? Of course if it pops rcd without a loft box then it says a lot....
I think you should ignore this "high reading" I don't think that is related to the tripping.That still wouldn't explain this high reading that he was very concerned about, or perhaps the tester is wrong from what some if you guys say the high readings are almost expected.
sorry if I sounded negative to you Robbio,HiYes I have and the rcd doesn't trip. 6 other TV's in the house all plugged into loft box also work ok. So maybe the lg is faulty, i could take it to a friends house and see if it pops their rcd (quite big to get in a car tho) but if they don't have a loftbox is it a true test? Of course if it pops rcd without a loft box then it says a lot....
I don't have a problem paying anyone to help, my grievance is mentioning extra money when it's to do something he's already told me was built into the price in advance to cover 'these types of scenarios'.. Especially when he doesn't seem to even understand it, he was blaming everything he could from remote control light (which is on light circuit not ring) to 6 was surge protectors, the rcd plugged in the garage socket for the lawnmower and i think the unplugged kettle got accused at one point too.
it seems that he has got 'joe from the pub'Any Part P registered electrician has a complaints procedure, as a homeowner you have this right to complain. A competant electrician should be able to identify all faults by proper testing procedures.Another requirement I have had to fullfill is that any inspection carried out as a third party has to be in a language that all can understand.
Saying that a reading is one, but gets larger as you go along the circuit,means nothing, other than my experiance telling me what "may" be wrong, but without absolute readings I like others will jump to conclusions.
My suggestion is to use your rights and make sure that you are happy with what your electrician has left you with.
Well that speaks volumes!!!He didn't test all the sockets, only a couple after the issues, with a plug in light up device. He didnt test any before starting work.
no contract' date=' not sure on his quals either..
Seems to me I'm in a stronger position to question him before I pay , thats why I came to your forum, you guys clearly know what you are talking about.
my big bad move was not asking him for proof of qualifications first.
[/quote']
These various snippets keep popping up along the discussion...
Your big bad move was NO formal contract..
and by the sounds of it not using an electrician who is a member of one of the approved contracting bodies...
(who will have a complaints procedure you can follow and bring third party into the evaluation of if theres IS a real wiring fault or plug in accessory problem)
Your stronger position..
Agreed if you have not yet paid him..
I would suggest you withhold a portion until you have received BOTH electrical certificates and Building regs compliance certificate.
Guinness
With all that has been posted I still stand by most of what I said in Post 8..
That's what I thought, but a few pages back the OP did a test where he connected an earth lead from a radiator to the aerial socket and it did not trip.I reccomend you try a different TV as I presume its the tv at fault and your aerial is giving the fault an earth somewhere along the lines.With all these TV's and DVD's etc all sharing a common aerial it only takes one of these to be a class 1 appliance and you've got an earth path.
and how much they were charged!I'm still waiting for the OP to do those tests (unplug and re connect one cable at a time) to tell us exactly what causes the trip, and the sketch of how it's all wired.
WAS nice! unfortunatly this is my old van which i drove into a ditch and wrote it off:coat , i have a white caddy at present and uming and ar ing whether to get it redone or buy another yellow one to stand out like before.Nice signage on your van monkey. Was it expensive? Looks like it's been wrapped?
