I wonder if anyone can help me. I have just bought a nearly new cooker, ( it was returned to shop as was to complicated for previouse people was fully tested before bought so got it for a good price)and had a electrician install it today. But it's not working.
The cooker is A AEG 493321i MN freestanding cooker with induction hob and double oven.
When you switch it on the display comes on but shows. error code E8. Then it shows child lock on. I press unlock and then next to two of the ring indicators it shows E which according to instructions means malfunction.
You can adjust temperature on other 2 rings but they don't switch on or get pan hot. ( I am using correct type of pans for induction Hob).
On the oven side the clock flashes but you can't set it as pressing buttons does nothing and ovens don't switch on.
The Weird thing is the fan is continually running with ovens switched off.
It seems like electricity is only getting to display and fan as none of rings or ovens will swich on.
I have googled E8 and it mentions this means a connection or loose wire problem.
What could be wrong with cooker, could it be the electrician did not wire cooker properly. Or do you think cooker is broken.
I have contacted electrician but he is refusing to come back unless I pay again.
I can't afford to pay for another electrician to come out.
Is there any thing that can be done to get it working, as really need it working as have 4 young children and need to be able too cook for them.
Also is it worth me contacting AEG.
Would it help if I posted some pictures of wiring at back of cooker.
Any advice much appreciated, thanks in advance.
