AAAMUSEMENTS
- Jul 29, 2009
- 422
- 0
Recommissioned the heating a couple of weeks ago, just before I went off on hols.
As we had done some work on it over the summer, lowering a radiator and replacing two others, I comprehensively bled all the radiators as the system filled.
Just had time to test it for a few hours, to find that the radiators are not getting as hot as they should be. Bled the radiators (again) to find that plenty of air had got in.
Although the boiler (contained within an oil fired range) seemed to be getting hot, I could put my hand on the flow pipe where it exits the boiler, with a minimum of discomfort.
I then bled the upstairs radiators AGAIN to find that more air had got in...
The system always used to get air in it, and I have had to bleed the upstairs radiators constantly over previous winters but never as much as this.
It's a vented system with no valves; when the pump is off for the heating the water is meant to still circulate via gravity to the hot water cylinder (although the water heating has never been very effective).
Any ideas? ?:|
Any ideas? ?:|
