Alteration To An Installation
r.b
Feb 8, 2011
379
on a electrical cert a classic example is a fuseboard change, I was just wondering if say you wanted 2 extra sockets on an existing ring and you had to install extra new cable to make it a ring again is this the same thing it would go down as an alteration to an installation?
Minor work's for me too. But iv'e not wrote a cert in ages, my polish mate write's them for me as he goes into more detail :coat
im confused OP, are you saying if you done a fuseboard change and added a couple of socket would you use the alteration box?
Or are you asking what form to use?  We seem to have a mix of answers above.
Im just saying a fuseboard change would go down as an alteration on an electric cert.I didnt mean just change 2 existing socket fronts for new fronts which would be a minor works.I ment altering the existing ring for 2 new socket fronts i.e splitting the ring under the floor joint box and making it a ring with new cables to your new 2 sockets this would be alteration surely of a circuit?thats my call anyway
+1 prodave. That wouldn't warrant any paperwork but cutting into ring for additional sockets is a minor works not an eic. Eic is for new circuits or change of cpd :)
Have to agree with Dave and Matty
Replacement CU - alteration on EIC
New circuit - addition on EIC
Altering or adding to an existing single circuit - MWC
Altering or adding to several existing circuits - alteration on EIC (or MWC for each circuit)
Just read the posts on this;
I am not sure if I have a crossed wire on this one;
OSG states; replacement of consumer
unit or distribution board, needs an EICR.   Page 151.
When the OSG says replacement, I read that as re-positioning
and not just new kit.  Replacement could mean renewal.
I do not read "alteration on EICR" as matching what OSG says.
Not nit-picking, just observing.
Good point Sharp;  yes, the EIC for the work. i.e.
replacement.  I should have said EIC, I said EICR.
Page 152;  the EICR is used after periodic has been
carried out.
If you look at it in the round, as it were, the board
change or replacement is a change of characteristics,
as you said.
installation cert for a mains change and minor works for the extra sockets as you're altering the ring circuit. not installing a new one
