who do what ???In my opinion, some customers think a lot more of you if you stand by doing a good job, but then there are others.
You are not building a toilet with or without a window so its not up to you to make sure his existing toilet conforms to part C.So the next scenario is I fit 1 socket per room
no extract in wc.
I certify and notify
Customer decides to sell to another Knowledgeable gent, who knows building regs like the back of his hand, and asks why i rewired this one with no extractor only one socket in each room and second hand pendants which are not even energy efficient!!!!!!!!
:red card
In the letter from the customer, you will note that he uses " you have advised us, but we don't want"You are not building a toilet with or without a window so its not up to you to make sure his existing toilet conforms to part C. You are doing a rewire so will fall foul of section 43© of AP L1B so need to install some tree hugger lighting. Also keep in mind that outside lighting has restrictions too and any old fittings may need replacing.
At the end of the day, the customer is the one who HAS to ensure all work is done to the building regs BUT if you self certify the work under Part P then YOU could also be liable for any breeches.
