No charge for the "look", quote would be provided before any work.
Costs would be + VAT + carriage.
Payment before the job is commenced, the only issue is that we would not have a test rig to run it on, however, IF it is an obvious fault then this is not necessarily an issue.
There would also be a warranty on the repair, obviously, but, it would run from the date of the repair, not the date when you use it!
In other words if you leave the card sitting on the shelf for 3 years then find it has a fault, sorry.
If you fit it straight away, and it does not work, then we will look at it again, no worries.
The only cost to you for warranty stuff, would be for shipping as it is a return to base warranty.
Only trying to be fair and give you an idea of what to expect, so that you enter into any transaction with your eyes open.
If you have any other queries, then please ask, once, if, you are happy, then we can arrange to get it sent in.
