- Feb 10, 2009
- 342
- 17
Working in a flat today which has one of these controls.
There a four rooms, each has a thermostat and has (or used to have) 1 or 2 convector heaters. On the face of it I assume that this control is just a clock controlling the four zones and each of the four rocker switches enables the user to choose between timed (AUTO), HIGH & LOW for individual zones.
Now I would understand if these choices were AUTO, ON and OFF - but HIGH and LOW implies different levels of heating and not just ON and OFF. But I can't see how this is achieved.
I tried experimenting with the stats and the timer/override switches but only the stats seemed to actually have any effect.
In the CU there is a 5A fuse marked HEATER CONTROLS and 30A marked HEATERS. The 30A appears to be a RFC. I'll test this in due course.
As I said each of the rooms used to have 1 or 2 covector heaters - some have now been replaced with storage heaters.
Flat is currently empty - previous occupier has died - so nobody to ask how set up works or if clock has deliberatley been bypased!
Anyone seen this set up before?
Anyone have any info/instructions for this timer EBERLE 610/4 ? (I have tried Google)
Thanks.
Thanks.
