plastic staples batty specially for t&eDon't think they are suitable for mains voltage cables so no.
They are. You can;t use standard metallic staples but there is a stapler out there that takes insulated staples for mains wiring.Don't think they are suitable for mains voltage cables so no.
Good exscuse to get a bigger van thoit might hang over the edge of your tool bag a little :^O
If you was doing all new build should speed up the fixing of back boxes and maybe extend the life of your battery drills ; );If you're going to that extent the Spit Pulsa 700E is on my list of things to get. Just need some more decent commercial work, not much use for the odd bits of commercial I do ATM, need an industrial estate or office block too do again. Can;t see it being required for any domestic work either!
They only do 1mm and 1.5 cables so not really very useful.
your right batty how daft of them if they'd of included 2.5 then it should be a great tool as long as it does what it says on the tin and the clips are durableThey only do 1mm and 1.5 cables so not really very useful.
