OK, leads, Hmmm.
Uk MD of Kewtech told me their remote lead fitted.
It don't I found out after buying one!
Anyone want a Kew remote probe, never used, just taken out of the packing!
I got the 53 as it has the reduced IR test voltages, I can use it on low & ELV control panels, plus the ramp test & the earth rod.
Never used the comms bit.
The Flukeview I had was an old clunky type and did not go anywhere near forms!
As far as the leads go except the remote probe which you are stuffed with you have to go Fluke, I have found the Kew leads excellent!
I will replace my leads with the Kew ones as and when I need.
I am not sure what you can download from the Fluke to.
This claims to be NIC forms & Fluke compliant, also does cable calcs.
http://castlinesystems.co.uk/
HTH
Paul
