Appliances giving off shock
sheffys
Aug 10, 2011
2
I have a washing machine and a microwave giving off a shock if I touch the sink.Both the appliances are plugged into seperate sockets. Any ideas as to the cause please.
Wonder if its the appliances at fault or the sink?
Could be a lack of bonding on your house electrics,
Or faulty appliances, (weird both being faulty though)
Do you know what type of electric supply you have?
Could you take a picture of your main electric board fuse and cable please?
TBH it could be a number of things, or a combination.
any one live in Blackburn area available to give this guy a hand if required ????
Is the immersion heater switched on when this happens ? Its often a faulty heater . But could be faulty wiring feeding your sockets.
Or vice-versa try turning it off , (I don't know if you are a sparks but you need one) buy a cheapo neon screwdriver and stick it on the sink , get someone to switch circuits off till the neon light goes out .
YOU NEED TO STOP TOUCHING THE SINK UNTIL IT IS SORTED !!!!
( Ducks into trench as the anti neon guys open fire)
If you are a Dark Arts Practitioner , shove your tester in the sockets .
I like this Deke,
my initial thoughts if the sink is not 'live' are a TNCS with a differing potential between sink(true earth) and appliances (supplied earth),
bvut that would involve a distance between Tx and supply and
[would be impossible as TNCS = PME! ] or could this possibly be the case?
BTW, Blackburn isnt a million miles from me, I work close by quite often.
