What about reversed polarityGot a power circuit powered OFFbut the neutral cables still arching and sparking can some one tell me why this happens??
Because you have the wrong power circuit switched off by the sounds of if. Or you are disconnecting the wrong neutral. Either way we need more information. domestic or commercial, single or three phase, what voltage and or current have you read down this neutral? I presume you have metered it out to ascertain what voltage is there. Whats the earthing type? If it is a domestic and the whole installation can be de-energised it would probably be no more than 10 mins to identify exactly which circuit the voltage is coming from. Photograph would also help us give a more precise answer.Got a power circuit powered OFFbut the neutral cables still arching and sparking can some one tell me why this happens??
If the cable belonged to the correct circuit and the circuit has been broken there will be no current flowing whether it is correct or reverse polarity. This has got to be a connection between circuits or the incorrect protective device has been identified.What about reversed polarity
