- Feb 5, 2009
- 5,612
- 1
When is arctic cable used for domestic?
Car keys in a bowl type of hook up?A favourite among caravanners to power when they hook up on site.
... and what type of cable would you wire up Uranus???If you wanted to wire up some lights on the moon would you use twin and moon cable?
Think you need a specialist website for that sort of wire... and what type of cable would you wire up Uranus???
you been on the wine vicar.?If you wanted to wire up some lights on the moon would you use twin and moon cable?
Applaud SmileyApplaud SmileyApplaud Smileyit would be fine I suppose to use twin and earth, as long as you isolated the earth at the moon end and made sure it couldnt come into contact with moon in anyway whatsoever.the potential difference between earth and moon would be much greater than earth and true earth mass and I very much doubt the CPC would carry the fault current.
I think a TM system would be required in this situation, perhaps with the addition of an additional satellite spike if required to get the necessary MLI reading to an acceptable level,
remember though that the MNCS is still not an acceptable system for the garage.
