paul b b
Evening Chaps,
ok, job today, move socket from left had side of wall to other and disconect 2 fuse spurs that are no longer needed.
firs find out that 1 spur is needed, then find out that the ring is not a ring and is fed via jb from somewhere ( customer did not want me to chase the cable back) so i put the existing spur cable into a new fcu nr ceiling where customer asked, all ok, test first socket all ok, test second socket revers polarity, check wires all ok, test again, check wires again, still the same all looks ok first socket works fine second not, though all wiring looks ok.
any ideas?
paul
any ideas?
paul
