phil d
There was a piece in PE this month that confirmed to me what I had suspected for ages, not only do some of the readers not have a clue, but neither do some of the writers.
There was a picture sent in by an "electrician" of something he'd found in the maintenance shop at work, it was basically a fuse carrier that had been modified, it had 2 wires protruding one from either end and these were connected to the screws where the fuse would normally be attached, the other ends were attached to an MCB. He said it wasn't right, and the "expert" in the magazine made some comment about it not being correct.
Now, when you look at it, and given the fact it was found in a drawer in the maintenance shop, as a pose to being attached to a board, should, to anyone of any intelligence given a good idea of what it really was, a test device, made by an electrician. Given the price of some of the fuses, it seemed a good idea to me, when you've located a fault and repaired it, then using an MCB to test the circuit, seems a good idea, it's not too different to the "fusemate" that the DNO use, after all, that is basically an MCB, albeit a remote controlled one.
It makes me wonder what these people would think if they saw some of the strange things I keep in my toolbox, and I bet I'm not the only one.lol
