retired electrician here so apologies if this is obvious to you folks currently working but my grand daughter has bought a bathroom mirror cabinet that lights up with leds.
Problem is its USB powered, it has a female type 2 plug on the back of it.
How can I get a 5v usb supply to the back of a mirror in a bathroom?
I was intending to install a >2.25m high single socket RCD plate (older Wylex System without RCD on the board) and run the cable done the cavity to the back of the mirror but I don't know how to get 5v supply from there. I looked at LED drivers but they all seem to be 12V and higher.
Again, apologies if this is a stupid question, I'm a bit out of touch with the newer stuff.
Thanks in advance
Thanks in advance
