Hi all
posted before I’m on a small farm with solar already but grid tied . I’m thinking of using forklift batteries as my storage source my questions are this - I’m wanting about 48kwh usable power I was thinking 24 cells at 2v 1240 ah batteries using the formula volts x ah divided 1000 giving me about 59 kWh taking off 20 percent as you can’t fully discharge a battery . The battery bank would be connected is series , have I worked this out right , I would be charging with 16kw of panels and using 2 8kw sunsykn inverters. The batteries are expensive and have seen used batteries at 930 with a year warranty but would fail to get the storage is there where parallel connecting would come in or series parallel? And am I right in thinking that I could keep the volts the same and increase storage ? And what would the formula be to work out kWh? ( to add all the volts up as before ?
thanks Roger
thanks Roger
