Hi,
My first post here but I have been reading other posts relating to Baxi Solo pump issues.
I am trying to figure out if I have a faulty PCB or if it's just wired wrong. The pump runs all the time except when I shut off power to the boiler completely.
Here is a photo of how things are wired going into the boiler...
I am slightly confused as to why the neutral and earth for the pump aren't wired into the pump section but instead the other side. Should it also be wired into the switched live.
I thought about moving the neutral and earth across to the pump side but I wasn't sure if that was right or if it would event make any difference.
Thanks,
Jamie
Thanks,
Jamie
