Thanks for your suggestion, to fault find set hot water to 'on' on controller, turned cylinder stat up til it changed state and noted the valve opened, measured voltage across valve limit switch to prove it had activated, boiler and pump both kicked in, turned stat back down and noted valve close and limit switch change state. Boiler turned off, pump still running, I'm aware pump should have run on time but this thing will run all night unless power turned off.---------- Post Auto-Merged at 20:52 ---------- Previous post was made at 20:40 ----------
I appreciate that steptoe sorry to mess u about, am on the verge of calling Plummer anyway, just having quick look myself.
