Baxi w/m 50/4 RS boiler with a ACL Drayton (Invensys) Lifestyle LP241 24hr Programmer MK4 Can I fit Wall Stat?
123martin123
Feb 13, 2012
2
hi can any one help me i have a baxi w/m 50/4rs boiler with a lifestyle LP241 controller my question is,, can i fit a wall stat? and how is this done ie wich way is it wired. there is a hot water stat on the system thanks
Wow, thats an old boiler, your lucky its still going. Yes, a wall stat can be connected to this. It should be connected in series with the feed from the programer.
---------- Post Auto-Merged at 16:43 ---------- Previous post was made at 16:35 ----------
If your taking the new cable to the boiler then turn off (isolate the electrics). You need to run a 3c & earth cable. Remove the core from the S/L terminal and join this with the black of the new cable into a joint connector. Connect the new brown core into the S/L terminal. Connect the Grey of the new cable to the N terminal & the earth cable to the E terminal (other cables should already be in the E & N terminals). At the wall stat end the brown & black are your switch, the grey is the neutral and the bare earth is earth. The bare earth should be sleeved green& yellow, the grey sleeved blue & the black sleeved brown, all at both ends.
Not all room stats require a neutral.
thanks for the info..old boiler but it works well, wired in the wall stat and it works well thanks again:
