bbq
bob
Mar 23, 2008
294
i have built a brick bbq and want a rotisserie, but cant find one and was thinking of making one :) how hard do you think they are to make? :|
bob
i was thinking a whole chicken or 2, because the grill is only 550 x 300mm, all i can see that i need is a:
rod (mild steel, SS (v.expensive), alu)
motor (i was thinking synchronous or permantly borrow admins shed motor :D )
some berings (that i can take out when finished)
some cogs (worm drive)
i have a local steel fabricators neer me, but i want to do most of it, because of cost
bob
i was thinking a whole chicken or 2, because the grill is only 550 x 300mm, all i can see that i need is a:rod (mild steel, SS (v.expensive), alu)
bob
Bob - I think you are trying to over engineer things
Bearings don't get on well near a lot of heat. Wouldn't a bush do?
I think cogs add to the complexity. Something like an old cordless drill with variable speed. Steal the motor, wire through a rheostat (sp?)
i have an old cordless :D
would i need bushes or would a hole work because it wont be going very fast :)
would mild steel be ok or would i need it chromed, hopefully not need SS because of the cost, not much in the pot amt :(
bob
i have an old cordless :D would i need bushes or would a hole work because it wont be going very fast :)
bob
I'd go for a hole! If you have any metal tube to line the hole it will run smoother.
What about cast iron? Use a cast iron polker. Cost very little money!
SS not too expensive. Threaded rod? Could even use the old drill chuck attached to the motor.
cheers for that, i did not relise it was so easy
bob
i was only going to use it wen i need it, as i allways say it dont matter what it looks like the important thing is that it works.
bob
