torbrowser
Hi all,
About to start installing my Hybrid PV system on my house, i have many questions but i will work through them one at a time to try and keep things as simple as i can.
System
Growatt 6000w Hybrid inverter 2 x strings
16 x 385w Panels (2 x 8 panel strings)
2 x 3300w batteries.
Firstly i have been doing the calculations on the string size, here are my workings out.
8 x 385w = 3080w
O/C volt @ 25 deg C 40.6V x 8 = 324V
O/C volt @ 0 deg C (co-eff V oc = -0.25%) 324V x 0.25% = 0.81V x 25 = 344V per string
My Inverter is rated at,
6000w
550v d.c
Max input current 16.9 d.c A*2
What is not clear to me after reading the booklet, is the max voltage 550v per string
And what does the A * 2 mean after the input current.
Kind regards
Jack
System
8 x 385w = 3080w
6000w
550v d.c
Kind regards
Jack
