- Nov 28, 2009
- 14,725
- 897
Today I had to fault find a non working fire alarm.
It's a a British Legion club, adjacent to a small town museum. They used to be one building which was split in two but they swear blind the fire alarm was installed after the split.
Anyway I locate the power supply box in the plant room of the museum. No mains power getting to it. Follow the wires. FP200 cable to an old MEM switch fuse, fuse okay, no power to the switch fuse. Carry on following the cable, this time through some trunking where it emerges as a bit of pyro to another MEM switch fuse. Again fuse okay no power to the switch fuse. Keep following, it goes through a (now bypassed) mechanical time clock, and then still as pyro up through the ceiling with no access. still no power.
At this point I decide to abandon fault finding the original convoluted feed, and instead connect the fire alarm supply directly into one of the 3 Wylex consumer units right next to the alarm supply box.
So that's it power back on, alarms working.
So first observation, why did the alarm installer choose such a carp source? why didn't he just connect directly into the adjacent CU?
But the really bizarre thing is we can't find any fire alarm control panels in either building.
If you trigger any fire point with the test key, the alarm sounds in both buildings, and reset the fire point the alarm stops. They say it's always been like that and they have never seen a control panel anywhere.
I think this is the first time I've seen a fire alarm without a control panel. Is this okay to leave it like that?
I don't normally do alarms, just things like this where I fix a missing supply, which apparently the alarm company were incapable of doing. If the alram does need upgrading, I'll be advising them to get an alarm company to do it (but a different one to the last company they used)
