Black Stainless Steel switched spur
Mike P
Oct 21, 2008
226
64
Southampton
Hi Guys. Looking for a manufacturer that produces a 13A switched fused spur, No neon and a Recessed switch. I can’t find one but one of you guys might know someone.
No idea exactly what you call black stainless steel?
Do you mean a stainless steel accessory with black inserts around the switch?
Or the whole accessory is black.. i.e. NOT metal (steel) looking colour?
But TLC have various permutations of black Fused Spurs..
https://www.tlc-direct.co.uk/tcl/search?query=FUSED SPUR&sort_order=&category_id=
Also not 100% sure what you mean by recessed switch either... ?
Switches normally need one bit sticking out so you can push it in/up/down to operate it?
More info needed.. and/or, example of another accessory in the finish that you required the fused spur to be?
