Hi guys, got a couple of questions,
2 walls lights are wired from the same switch, and both have bulbs have blown within 1 week of each other. At the switch there are 2 cables coming in. 1 cable has 2 browns going into L1 and other into L2. The other has brown into common and the neutral has just been cut and left in the back box?
2G 2way switch in kitchen has 1 switch going to security light which works, other switch controls 2 lights in kitchen (1 works but the other does not) but I believe the light is faulty as there is power to both. My question is about the wiring of the switch. All neutrals are together in a connector block and they have run a strapper cable from the common in 1 switch to the other?
Any ideas please?
Any ideas please?
