I have a Glow Worm Ultimate 50BF Boiler, its about 15 years old but normaly works fine.Recently after being on for a few hours it shuts off & eventhough the room stat & boiler stat are calling for heat it wont fire up.The motorised valves are working ok when I alter the thermostats.The boiler stat has always been set to full.The system has a 3 speed pump that has always been set to speed 1.When this problem occurs the boiler will fire up and run normally if I set the pump to speed 2 or 3.Could this be a pump fault or possibly a boiler stat problem.Any advice would be gratefully received.
