bonding again
Jonnyboy 68
Apr 25, 2010
26
hello all ..
I recently posted a question about the need for supp bonding where all circuits are RCD'd, main bonding is in place etc... and also the need for bonding where the incoming water is in plastic.. many thnks for your reply's. You all advised that I measure the resistance of the internal copper pipework ... at which points do I measure from .. presumable the MET and where ? What's the easiest way to do this ? Cheers :C
Met to the pipework using a wander lead would probably be the easiest method.
