Theorysparky
Domestic Electrician
- Feb 18, 2008
- 4,232
- 0
steps
you just don't put enuff rods in !!!!
Batty has summed up this thread very accurately in the above statement I think..Well if they pass you with the knowledge you have this will explain why the electrical trade is in the state it is. I am sorry but this is basic stuff surely you need to know the basics before going out into the big wide world and earning a living doing electrics.
I hope not as well
I've a workshop at the bottom of the garden which is obversely on a TT system and therefore seprate to the DNO earthing.
so it looks like I'll be watering the plant next to the earth rod or praying for rain just before he comes around to try and get under the magic Ze of 21ohms.
Plus I better brush up on the earth rod impedance test.
Yes; I get this but are sockets not also provided with two connectionsonly at the board. sockets probably have both earths in the same terminal
thats a nice reading slips,I connected my first TT install (builders supply) in years today. 1 rod and i got 90hms , although i dont do much TT thats the lowest i have ever got ( even after drenching the ground)
you've never been on the Isle of Man, they dont call it the rock for nothing,You need to get out into the country slip/steps around my way its usually around 30 ohms.
same up here. mostly 20-40 ohms. rarely get anything over 100You need to get out into the country slip/steps around my way its usually around 30 ohms.
Where do these magical figures come from.I hope not as well
Try calculating the earth fault current if you have a 21 ohm rod, then and look up the disconnection time for a 32A type B MCB. Will it comply?Max Ze of a TT system anything over and you need a RCD.
But as you need an RCD on a TT system anyway it is a bit irrelevant but if he wants to get picky anything over 21 and protection is down to the RCD.
Some people don't like it as protection is lost if the RCD fails.
Introduction of the onsite guide page 11
542.24
