jgwestray
Hello everyone.
I am hoping that someone one her may be able to help me.
I have just finished installation of a off grid Solar system. However I have come across a problem.
When i run the 240v system in the caravan from a mains or generator source everything works fine.
Once I switch over to the 3000w peak 6000w inverter the voltage reducer in the caravan starts to buzz.
There are three 240v outlet fuses in the consumer box. The two that don't use the power reducer work fine. Powering my TV fine. The fuse that powers the reducer works fine and does not trip. However the reducer buzzes like a nest of hornets. It powers the 12 volt circuit and 240 circuit it supply's. But it deffo should not buzz like it is. Switch back to mains or generator feed the buzzing stops. ????
Any ideas what I have done wrong please
