Good afternoon all.
Brand new member, 1st time poster.
I have the above installed at home. Lived here ten years and no problems whatsoever. Recently the alarm has been sounding through the night and after some research have worked out the battery’s need replacing. I will replace both, the one in the control panel and also the one in the alarm bell box. I have them on order and am confident in how to replace them but I have read that in some cases it might lockout my panel and an engineer code would be required to re set it. Is this the case? If so how would I be able to get hold of the engineer code. I have no manual only the ones I find on the internet.
Thank you.
Thank you.
