cable options
matt.leung
Feb 26, 2009
1,062
Bromley, Kent
need some help and advice.....
quoting for drive over lights.. but trying to work out the cabelling. The cable routing will avoid any heavy traffic. The paving is block paving.
either - swa with underground back boxes = expensive option
hi tuff ?
Hituf multicore PVC cable is more robust than standard PVC sheathed cables and provides a quicker, more economical alternative for:-General power, control and fixed wiring uses.
Temporary wiring on open sites.
Hituf is lighter and more manageable than alternative steel wire armoured types and requires only nylon glands to install - factors which contribute to speed of installation and savings.
Provided there is no specific requirement for additional metal protection such as steel wire armouring, Hituf will meet the demands of the most arduous installation conditions.
Hituf will not ignite under extreme applied heat.
Current Rating: 20 Amps
